Power Consumption (Idle and Gaming)
Putting realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something we've experimented here at
bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how GPU will be used when gaming.
It's such a hardcore test that any GPU under test is almost guaranteed to hit its thermal limit, the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game like
Crysis running at a certain point also isn't reflective of real world use. There's no guarantee that the GPU is being pushed as hard as other titles might do, and the load will vary from play through to play through.
Eventually then, we've decided to use 3DMark06's Canyon Flight test as a real world representative, repeatable graphics test. It's a ferociously demanding test, pushing graphics cards to their limit, but also containing peaks and troughs in performance that match real world game play.
As the test is so demanding and GPU limited, we've set 3DMark to run the test at 1,280 x 1,024 with 0xAA and 16xAF (enabled in the driver), constantly looping the test for thirty minutes and recording the maximum power consumption and GPU Delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
        Nvidia GeForce GTX 460 768MB
        Zotac Nvidia GeForce GTX 460 1GB
        ATI Radeon HD 5830 1GB
        ATI Radeon HD 5770 1GB
        ATI Radeon HD 5850 1GB
        Nvidia GeForce GTX 465 1GB
        Nvidia GeForce GTX 470 1.3GB
        Asus Ares
        ATI Radeon HD 5970
        Sapphire HD 5970 Toxic
            136
            137
            138
            140
            142
            154
            160
            167
            168
            174
    Watts at socket
        ATI Radeon HD 5970
        Asus Ares
            224
            237
            246
            248
            270
            305
            341
            352
            439
            462
    Watts at socket
Thermal Performance
        Asus Ares
        ATI Radeon HD 5970
            9
            10
            13
            15
            16
            22
            22
            24
            25
            26
    Delta T in °C
        Asus Ares
        ATI Radeon HD 5970
            33
            41
            46
            49
            50
            53
            53
            54
            56
            72
          20
          30
          40
          50
          60
          70
          80
    Delta T in °C
Note: we tested the Zotac GeForce GTX 460 1GB card to obtain these numbers as it was the first GTX 460 1GB card to arrive. It uses a non-standard cooler, so isn't representative of every GTX 460 1GB card. Manufacturers didn't have reference samples of GTX 460 1GB cards to send us, and Nvidia couldn't supply us with a reference card either.
Read our Performance Analysis
